1990 XJS convertible antenna
Old Mar 17, 2016 | 09:37 PM
macdoesit's Avatar
Banned
Default 1990 XJS convertible antenna
My antenna does not go down, is there a way to check if motor is bad or maybe a fuse or loose wire.
Thank you
Old Mar 18, 2016 | 02:17 AM
Greg in France's Avatar
If you have a poke about in the space between the exhaust tunnel and the outer skin, near the aerial, you will find a largish green relay and also a line fuse. If the fuse is OK, then it is likely that the relay is stuck closed. Either buy a new one (it is a special one so OEM is required) or, carefully prise off the green cover and you will see a couple of contacts that look like old fashioned distributor points. If you clean these up and try it, the relay may well work.
Greg
Old Mar 18, 2016 | 06:26 AM
orangeblossom's Avatar
Thank you
Hi Mac
If you need a New one.
Jaguar XJS Hirschmann Electric Aerial Power Antenna New | eBay
Old Mar 18, 2016 | 06:37 PM
macdoesit's Avatar
Banned
I will try what Greg said first if motor is bad then I will buy the new that Orangeblossom found on ebay.
I have a new trunk lid spoiler on the way from UK so I must fix it.
Moseleykmc
May 13, 2020 11:50 AM
MissyBeeS
Apr 6, 2016 08:25 PM
WinterJag
Mar 23, 2016 02:40 PM
reichstall
Mar 14, 2016 07:43 PM
Roger Mabry
Mar 12, 2016 08:57 AM
