1990 XJS Fuel Line
Old Oct 13, 2011 | 01:53 PM
stonehenge kid's Avatar
Default 1990 XJS Fuel Line
Looking for a little wisdom on the clacification/corrosion on the line -
Please see pics attached here -
Trying to determine if this may be cause of fuel odor in trunk/boot -
Thanks,
St. Kid
Attached Thumbnails 1990 XJS Fuel Line-jag-trunk.jpg   1990 XJS Fuel Line-jag-trunk-2.jpg
Old Oct 13, 2011 | 03:41 PM
Fraser Mitchell's Avatar
The XJS is notorious for corrision, (rusting), on the hidden side of the fuel tank where it abuts the rear bulkhead. This eventually results in pin-holing and leakage of fuel. Only way to check is to heave the tank out and look !
Old Oct 13, 2011 | 08:46 PM
Doug's Avatar
Fraser's right about tank leaks.
But, yes, the lines do leak as well. And it need be more than just a trace of a leak. In the confines of a closed trunk even a tiny leak makes a big smell.
A tip I learned was to wrap all hose/pipe joints with colored tissue paper. Even a tiny seep will stain the paper, reveling the leak.
You'll probably have to remove all the trunk carpet for a thorough cleaning. it really holds the odor even after you find and fix the leaks.
Old Oct 14, 2011 | 09:30 AM
ThQ, Fraser and Doug -
I'll try that tissue paper trick. I have about half the carpet out and it's still not clear if this was something spilled or a leak or what.
Of course, I'd love to avoid pulling the tank, but am fed up with the situation.
Still a relatively new purchase and I believe I can go back at the dealer to recoup some cost if tank does need out -
I'll check back with anything I learn,
Thanks again -
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
Bcrary3
Feb 21, 2023 04:29 AM
sadepol01
Sep 11, 2015 05:26 AM
deanh
Sep 6, 2015 08:20 PM
