1990 xjs rouge no spark no fuel injector click
Old Jul 31, 2018 | 10:13 AM
John Lesley's Avatar
Default 1990 xjs rouge no spark no fuel injector click
Hi purchased a 1990 xjs not running. Cranks but no start. No spark at coil wires. Fuel injectors no clicking, getting power to coils Marelli ignition. Car was running went out to start after sitting overnight no start since. Crank position sensors recently replaced with genuine Jaguar parts before the no start condition I find it hard to believe they would be bad. What else should I check for?
Old Jul 31, 2018 | 10:18 AM
Welcome to the forum John,
I've moved your post to the XJS tech section.
Please post an intro in the new members section when you can.
Old Jul 31, 2018 | 04:46 PM
warrjon's Avatar
Primary inputs for starting are
- Front crank sensor (TDC sensor)
- Engine speed on the flywheel
- MAP sensor
A no spark condition it will be one or more of these. Check the connectors and check clearance on the crank sensors they must be less than 0.040" away from the reluctor wheel.
Old Aug 1, 2018 | 11:26 AM
Thank you for your help I will check tps clearance and the map sensor when I get home this weekend thanks!
Old Aug 2, 2018 | 03:55 AM
warrjon's Avatar
Not the TPS the crank sensor.
Old Aug 2, 2018 | 02:41 PM
Sorry I meant crank sensor
Jag4me2
Jun 11, 2012 01:31 PM
Sixx Dogg
Jan 1, 2012 12:30 PM
I-RIGHT-I
Dec 20, 2011 04:22 PM
A Dopo
Jul 14, 2011 04:44 AM
Rev
Mar 4, 2009 09:53 PM
