1991 xjs speedometer 10 mph slow
Old Jun 13, 2018 | 09:39 AM
Dcarver7's Avatar
Default 1991 xjs speedometer 10 mph slow
Jaguar XJS indicates 10 mph slow after return from shop. Mechanic said he forgot to do something. He no longer works in area. Any idea?
Old Jun 14, 2018 | 04:06 AM
bladerunner919's Avatar
What work was it in the shop for? Seems like an odd symptom to result from someone forgetting to do something, unless he forgot to put the correct wheels or diff back on it!
Old Jun 14, 2018 | 07:07 AM
J_C_R's Avatar
I recently solved my speedo issue, had to replace the speed sensor on the tranny. But mine had the classic symptoms, either it would sit on zero, or jump all over the place.
It's a pretty much "plug and play" repair, take the old sensor out and put in the new one. There is no adjustment or calibration needed. Not sure what he could have done to make it act that way.
Of course, maybe the one he put in is bad and failing in a different mode. It's fairly easy to replace, you can certainly do it yourself if you have jacks/ramps to elevate the car a bit.
Thanks,
John
1987 XJ-S V12
lonejag
Feb 7, 2019 03:58 PM
yachtmanbuttson
Jun 8, 2018 05:39 AM
corrado1992
General Tech Help
May 18, 2018 12:49 PM
Brummel1
Apr 29, 2018 06:28 AM
