1992 xjs v12
Old Feb 27, 2014 | 08:51 PM
vh-atr60's Avatar
Default 1992 xjs v12
I was driving home last night and for no reason the speedo and fuel gauge simply stopped working. Fuel read empty and speedo read 0
Any ideas
Old Feb 27, 2014 | 10:07 PM
Doug's Avatar
I'm guessing loose/dirty/corroded contacts on the instrument cluster printed circuit....fairly common for the gauges to go flakey as a result.
Not that big of a job to pull the cluster and clean the contact points....and add a redundant ground/earth on general principles.
Old Feb 28, 2014 | 05:41 AM
o1xjr's Avatar
Default Similar gauge trouble
I had a similar problem with my XJ6 a couple of months ago. Fuel gauge and oil pressure gauge were going up and down more like a tachometer and dash light switch was working like a Lucas switch does,intermitent. So I removed the gauge and switch cluster disconnected all wiring(take pics or make sure you have the correct wiring diagram for your model).There is 45-50 wires in there.
Cleaned all contacts and replaced some as I went where plastic shrouds were perished, removed the printed circuit and gauges. Gave everything a light blow out and removed switches and cleaned them,reassembled the whole lot. Took about 4-5 hours in total.
Nothing has missed a beat since,except clock looses 2 minutes daily.As you can see by clock I just went down the garage to take pics of my dash and my spare so you can see printed circuit,I assume yours will be much the same.
I have added pics of printed circuit,this is fragile so take care.
Good luck
Attached Thumbnails 1992 xjs v12-dsc_8300.jpg   1992 xjs v12-dsc_8301.jpg   1992 xjs v12-dsc_8302.jpg   1992 xjs v12-dsc_8303.jpg
Old Feb 28, 2014 | 06:50 AM
Steve M's Avatar
I have a similar problem with mine and it is a loose fuse or holder; if I prod it the instruments come back on (it's in the underdash fuse box below the steering wheel (right hand drive).
Old Feb 28, 2014 | 04:18 PM
cat_as_trophy's Avatar
Hi vh-atr and greetings from the Coffs Coast in NSW;
Welcome to the forums. We are a happy, friendly lot here ... first names tend to be appreciated as anywhere in Oz, but not mandatory. Please trot over to the "New Member Intro" thread, tell us a bit about yourself and your car, and you will get some great tips on how to use the excellent knowledge and downloadable resources on tap here, as well as get a rousing hello from all and sundry.
Like you now find with your reported problem, technical queries are best directed through the model-specific section, but all of us Aussies, Kiwis, and not a few international "wannabe convicts" hang out here pretty regularly on the regional Aus/NZ forum to chew the fat, discuss Jaguars, engage in the occasional banter ... and generally enjoy each others' experiences and friendly advice.
I hope you enjoy.
Best wishes,
Ken
BadKat174
May 26, 2023 12:29 AM
JWheeler
Nov 22, 2019 08:28 AM
alextoevs
Sep 20, 2015 05:21 PM
DrTripp
Sep 14, 2015 07:58 PM
d a
Sep 3, 2015 02:34 AM
