1992 XJS V12 Odometer stopped working
Old Dec 10, 2023 | 03:08 PM
FarmerPete's Avatar
Default 1992 XJS V12 Odometer stopped working
Hello. The odometer and trip odometer on my XJS stopped working. The speedometer works and the trip computer works. I pulled out the instrument cluster, lubricated the odometer and cleaned the electrical connections. Still no luck. Any suggestions?
Old Dec 16, 2023 | 10:44 AM
Mac Allan's Avatar
From your description, it sounds like the internal gear is at fault. They are plastic and can crack with age.
Not sure where you are located, but if you have a speedometer shop nearby they can either fix it or provide the proper plastic gear. If you don't have one locally, you can contact Palo Alto Speedometer and they should be able to help.
Palo Alto Speedometer: Repair, Restoration, and Sales of Automobile Gauges
Old Dec 17, 2023 | 01:22 PM
malc4d's Avatar
As its often really important where in the world the car is, l was just thinking wouldn't be great if there could only be a way to put that information on the posts......
Old Dec 19, 2023 | 06:08 PM
FarmerPete's Avatar
I don't think it's a mechanical problem, because the odometer turns correctly if I manually turn the primary gear.
What is this electrical component and is it possible that it has failed? Is there a way to test it?
Old Mar 16, 2025 | 08:45 AM
Challenger's Avatar
This is an old post and it is exactly what I tried to ask in a very recent post but no replies, and as it describes my situation better than my post, I am reviving it in the hope of a reply
I know this is the motor that drives the odo meter but I dont know how to test it. I am worried if I give it current it might burn or something.
Did anyone face/resolve this issue before?
My speedo works but not the ODO where as on the computer it is working ok, and my car is a 1992 XJS V12.
Any suggestions please ??
sanchez
Mar 23, 2023 05:57 PM
JayJagJay
Jul 21, 2022 05:32 AM
Bob95XJS
Feb 10, 2022 05:22 PM
JagV12
Nov 3, 2014 07:14 PM
