1993 Jaguar XJS A/C Vents
Old Jul 2, 2024 | 07:12 PM
Jbaker229's Avatar
Default 1993 Jaguar XJS A/C Vents
Alright, I am getting through all of issues on my XJS. Question on the very far vents on the passenger and drivers side. My center vent puts out tons of air, but the vents on either side barely move anything.
Is this normal, or should I go digging to find an issue?
To be clear, both side vents are quite weak, so it makes me think there is likely not a problem. I have checked both fans and they work perfectly. The compressor is charged with R12 and it blows cold, but it would be nice to have these vents blow more for the uber hot days we have in Atlanta.
Thank you!
Old Jul 2, 2024 | 08:35 PM
jal1234's Avatar
There's an on/off thumbwheel on one end of each of the two vents. They can stick sometimes, and be hard to open or close. Check that first, and make sure they are both fully open. Other than that and making sure the ducts to them are properly connected,, there's nothing else to check. There are no separate dampers or shut offs for them.
One thing that can help is to remove the two ducts thru the lower part of the console to the rear seat area and cap off the openings on the HVAC assembly where the ducts attach. You will get a lot more air out of the front vents after doing that. You have to remove the console ski slope, console compartment lid, and console interior tray to get the ducts out and cap off the outlets.
Jon
Old Jul 2, 2024 | 09:29 PM
Jbaker229's Avatar
Jon
Thanks Jon. That answers my question. I was wondering if there is any additional duct work coming off either of the fans, and yes, I can feel beneath the center console, cold air pumping through the vents, right onto the floor. Weird design.
Old Jul 2, 2024 | 09:40 PM
jal1234's Avatar
Never made sense to duct air back there. Seats aren't big enough to hold a normal human.
Jon
Old Jul 3, 2024 | 05:35 AM
Mguar's Avatar
Pumpng cold air down at your feet where the heat from the exhaust is and hot air coming off the radiator etc exits underneath the car makes a lot of.sense to me.
I hate to have my face cold and my feet hot.
Conversely when the heater is on warm up my feet first because they tend to get cold first.
At least up here in the arctic circle ;-)
93xjs6cyl
Oct 19, 2022 09:37 AM
taperguy
Dec 30, 2021 05:08 PM
Soul23
Aug 8, 2021 12:50 PM
nikmott
May 7, 2014 05:18 PM
flyrr100
Oct 1, 2012 01:22 PM
