1994-1996 Cooling fan differences
Old Dec 16, 2019 | 10:10 PM
Benj628's Avatar
Default 1994-1996 Cooling fan differences
I have seen conflicting information that some of the US spec AJ16 models have electric cooling fans whereas others have the fan mounted on the water pump pulley cone. My is on the pump. But looking for replacement water pump and most of the ones I am finding don't have the bolt holes on the front for the fan to attach. Unless these listings are all using the wrong photos? The XJS pump is identical for the XJ6 engine water pump with the fan bolts being the only difference.
So does anyone here have definite info as to whether the XJS late models came with electric fans from the factory?
Old Dec 17, 2019 | 01:11 AM
Greg in France's Avatar
All XJSs left the factory with an engine driven main fan. V12s have an electric auxiliary fan mounted next to the engine driven fan. All the 6 cylinder cars also had auxiliary fans, some at least, if not all, being mounted in front of the radiator as a "pusher".
Old Dec 17, 2019 | 03:34 AM
ptjs1's Avatar
As Greg says, all AJ16 XJS have the same fan setup with the main fan being a viscous unit mounted on the pump pulley. See Jaguar's website here for fan units:
https://parts.jaguarlandroverclassic.../brand/jaguar/
and here for water pump:
Good luck
Paul
Roger95
XJ40 ( XJ81 )
Jun 27, 2018 09:20 AM
MK2
21
Apr 30, 2018 02:07 PM
rdssdi
Apr 26, 2015 10:09 AM
Big_Walleye
Jun 22, 2013 02:35 PM
georgia boy
Jan 25, 2011 12:55 PM
