1994 Jaguar XJS fuel issues
Old Jun 11, 2019 | 04:23 PM
Shannon Carter's Avatar
Default 1994 Jaguar XJS fuel issues
I have replaced the fuel pump fuel pressure regulator and fuel filter but I’m still not getting fuel to fuel rail any suggestions or advice on what to do or look for thank you
Old Jun 11, 2019 | 07:36 PM
Vee's Avatar
Vee
Wrong forum, but are you sure the fuel pump works?
Old Jun 12, 2019 | 01:59 AM
I've moved your question from General Tech Help to XJS forum. This is the place to post technical questions about your model.
Old Jun 12, 2019 | 02:46 AM
warrjon's Avatar
Is the fuel pump running? it should run for a few seconds when you turn the ignition on.
The fuel feed pipe runs under the car on the RH side, someone jacking the car up under the sill could crush the pipe. easy to check.
Old Jun 12, 2019 | 12:16 PM
JigJag's Avatar
Ensure you have flow at each junction between tank and pump. Possibly a clogged predicted screen in the sump tank.
Old Jun 15, 2019 | 08:18 AM
Paul_59's Avatar
Banned
As Warrjon says fuel pump should run for a couple of seconds to prime and pressurise fuel rail when ignition is initially turned on, it can usually be heard. It is worth checking this, failure can be due to a faulty fuel pump relay.
When engine is turning over either during starting or when running the fuel pump is energised by relay under control of Lucas fuel ECU provided ECU receives signals from crank position sensors
Gerryb4447
May 24, 2023 10:34 AM
hoodun
Jun 8, 2017 09:57 AM
rama1200
May 18, 2015 07:29 PM
FightinFire31
Jun 14, 2014 05:30 PM
Icarrya45
Mar 7, 2013 07:30 PM
