1994 warning light cluster on a 1995
Old Aug 28, 2014 | 05:21 PM
AndersA's Avatar
Default 1994 warning light cluster on a 1995
I just noticed that, according to the Service Manuals for the 1994 and 1995 models, my 1995 XJS, VIN SAJNX2746SC197944, has a 1994 layout of the warning lights above the analog instruments!
Not that it matters - the icons are the same but the order is different, but it seems weird. Is this normal Jaguar practice, to use up old stock before using new stuff?
Old Aug 28, 2014 | 06:13 PM
ptjs1's Avatar
Anders,
Hi, which part of the Jaguar Parts & Service Manual shows a difference between the instrument bulb order on "1994" & "1995" cars? This is not something of which I was aware.
If there is a difference, it might be the confusion by what the US call a 1994 or a 1995 car.
It doesn't work like that where the cars were made. Jaguar made periodic changes and designate those by what they call Model Year (MY). Cars built after April 1994 at VIN changepoint 194775 (when the AJ16 engine was introduced) are designated 1994.75 MY. But Americans seem to call this "1995". Then there was another changepoint in October 1994 at VIN 198335 (brake system changes) which is designated 1995.25 MY. I don't know what Americans call this. The next VIN changepoint is in April 1995 at VIN 221855 and when the XJS was then called "Celebration". This is designated 1995.5 MY. Again I don't know what Americans call this, maybe "1996"? The next changepoint is at VIN 222632, I think around August 1995. This is designated 1996 MY, but don't know what Americans call that if they had already used "1996"?
Your car, VIN 197944, is what is designated 1994.75 MY. If there is a difference in the Service Manual (which section?) it might be because your car is part of this series and built before the 1995.25 MY cars were built. If you lived over here in the UK, you would say that you had a 1994 XJS.
I hope that isn't confusing!
Paul
Old Aug 28, 2014 | 09:13 PM
AndersA's Avatar
Hi Paul,
Your explanation makes perfect sense.
So according to Jaguar I have a 1994.75, based on the serial number in the VIN, but they agree with the Americans it is a -95, giving it an S as the year maker in said VIN.
I've tried to find postable references to the layout of my warning lights, but can't find any. What I've got is what's depicted on page 45 in this link: http://www.jagrepair.com/images/Auto...4%20update.pdf, and not what's in the 1995 Driver's Manual that came with the car.
Old Aug 29, 2014 | 12:20 PM
ptjs1's Avatar
Anders,
That link refers to a North American publication of the introduction of the "American" 1994 MY car. This car has the AJ6 engine rather than the AJ16 engine in your car which was introduced in April 1994.
Confusingly, when the AJ16 engine cars were first introduced, Jaguar didn't seem to have a new drivers handbook ready for issue. My car is an early AJ16 VIN 196... and all the digarams etc in it refer to the earlier AJ6 cars.
However, the instrument diagram in the drivers book is the same as the one in that American publication and is the same as I have fitted in my car.
Just to make it more confusing, the diagram in the 4 litre Jaguar Parts & Service Manual (which is dated August 1993) shows a slightly different layout that is not consistent with the handbook, your publication or my car.
And the Jaguar parts system identifies a change in the circuit boards at VIN 194775 (AJ16 engine intro) but no changes after that.
Of course, we know that Jaguar sometimes produced publications with intended changes that never actually made it into production. So this may explain the inconsistency.
Can you post a pic of the diagram that is in your American "1995" drivers manual so that I can see the apparent differences?
Tks
Paul
Old Aug 29, 2014 | 12:53 PM
AndersA's Avatar
The attached file is a(poor quality) pic from the Drivers Handbook.
Attached Thumbnails 1994 warning light cluster on a 1995-screenshot-8_29_2014-11_39_46-am.jpg
Old Aug 29, 2014 | 01:07 PM
ptjs1's Avatar
Anders,
I've not seen that diagram before. It seems strange for an XJS for the following reasons:
- It says Sport Mode is not applicable. Not true
- It doesn't have a 1st gear lockout illumination bulb as it should.
- It has a caravan trailer light. That seems a strange need on an XJS
I'd be interested to hear if anyone actually has that layout of bulbs in their XJS.
Paul
Old Nov 17, 2014 | 11:00 AM
MHF25's Avatar
Default 1994 warning light cluster sequence
I just upgraded my instrument cluster to LED's and have some extra parts from some spare instrument clusters to include some gauges. One of these parts is the light indicator symbol strip. This is one is different from the one shown in the previous message. the first four symbols on the left are > exh temp, 1st gear, sport, tranny. The first four symbols on the right are > washer tank, rear fog, bulb out, front fog. Is this the strip you need? It is very easy to take out the incorrect one and put this one in. It is for vin numbers after 188105. I don't have a need for this strip. Let me know if you can use it. Mert25@att.net...
Old Nov 17, 2014 | 04:39 PM
Steve M's Avatar
Originally Posted by ptjs1
Anders,
Paul
My 1989 XJR-s (drum gauges) has the caravan trailer light too so it was a obviously a wired in option from earlier days.
Old Aug 16, 2015 | 11:59 AM
gerryxjs's Avatar
My thanks to all posters to this thread.
I have had trouble just trying to determine the position and function of all the “idiot” lights,and although mine is a 1992, the handbook relates entirely to a pre-facelift XJS and so is of limited value. No value as regards this thread.
I eventually pulled the dash for the umpteenth time and removed each bulb in turn, shone a flash light through to discover the icon. I have been trying to fit LEDs in an effort to brighten up the turn signals (at the very least) and could think of no other way of doing it.
Reading from left to right:-
Fog | Bulb failure (I think) | Sport |Fog ? | Turn | Hi beam | Anti Lock | Low Coolant | ?!? | Oil Pressure| Parking brake | Low fuel | Chk Engine | Battery | Seat Belt | Turn| Trailer | Transmission | Exhaust Temp | Low Windshield |
So unless my eyes are playing tricks it is not exactly the same layout as AndersA 's Jpeg.
I'd be happy to find a drivers handbook for a 1992 !!!
Old Aug 16, 2015 | 12:31 PM
ptjs1's Avatar
GerryXJS,
So what your 1992 MY car has is the same as the diagram from Anders a few posts above?
Drivers handbooks are usually available on ebay.
Paul
Old Aug 17, 2015 | 09:13 AM
gerryxjs's Avatar
Paul,
Yes you are correct. I meant to put up another post to say that on closer examination, Anders' jpeg is indeed the same.
I do keep an eye on EBay too, but have drawn a blank so far. This made me think that perhaps there was no such thing as a 1992 XJS handbook.
Many thanks.
Gerry T.
Old Aug 17, 2015 | 02:31 PM
malc4d's Avatar
That depends on what you have. Do you have an early Facelift car, from VIN 179737...I bought a new '92MY(1800**) handbook from ebay last year.
Old Aug 18, 2015 | 08:35 AM
gerryxjs's Avatar
My VIN is 181xxx so whether that is an early or late 92MY I do not know.
I checked EBay just yesterday and the book I saw on offer (as a 1992) was the same as mine. The 1993 on offer is perhaps a better choice.
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
Jpav27
Jul 31, 2022 06:43 AM
edtexas
Sep 4, 2015 08:20 PM
