1994 XJS V12 6.0 no start/run
Old Aug 19, 2024 | 11:09 AM
kansanbrit's Avatar
Default 1994 XJS V12 6.0 no start/run
Got the old girl out yesterday, started fine but idled a little rough. Tried to give her gas would not respond. Eventually died. Then nothing when cranked. Looked at her today. Some fuel comes out the rail supply pipe when disconnected but nothing comes out of the regulator out port at any time when outlet pipe left disconnected. Tried powering both pumps directly, both run but no fuel comes out of reg port ever. So some fuel supply but not enough pressure to open regulator I'm thinking. What could be limiting the pressure? I notice a 'damper' in the fuel lines, anybody know if that could be the source of my problem? All the injectors stuck open? No smell of fuel. She ran great a few days before, loads of power and smooth running.
Edit: Fitted a pressure sampling port. 0 PSI pump 1, 5 PSI pump 2. Surely they can't both be faulty ? That would be my luck !
Old Aug 19, 2024 | 12:48 PM
kansanbrit's Avatar
I fear I may have discovered the likely issue.
Old Aug 19, 2024 | 02:57 PM
equiprx's Avatar
He sure does a lot of talking about stuff we couldn't give a damn about.
I wrote a post years ago about how after pulling the tank in my 94 6.0.
Almost every hose inside the tank had loose clamps and one hose was completely disconnected.
Old Oct 27, 2024 | 04:57 PM
Jaguaralfonso's Avatar
The fuel pump N2 only acts when 2850 rpm is exceeded... Until then I think that the pump N2 does not activate and if the N1 does not provide pressure, try to see if the fault is in the Pump 1 relay that has the yellow socket, changing it for that of Pump 2 with a green socket
Old Nov 2, 2024 | 05:49 AM
kansanbrit's Avatar
Default Solved
Pump housings were both broken internally, had to modify them to stop them leaking. Good pressure now. Lots of photos if anyone needs them.
Old Nov 2, 2024 | 07:05 AM
Greg in France's Avatar
Please post the photos!
Old Nov 14, 2024 | 10:28 AM
kansanbrit's Avatar
Should not be a gap between pump and green plastic. Seal had blown out  Piece of plastic broken off, PO must have left it out.  Not sure if aluminum part is original.  Both pump housings had same problem.
Aluminum bottle cap fitted to prevent seal blowing, working so far.
AZDoug
Oct 22, 2023 03:00 AM
billythequid
Feb 10, 2023 04:36 AM
Jeff4605
Jul 18, 2022 05:48 PM
88-xjsv12
Jan 23, 2022 10:07 PM
J_C_R
Nov 14, 2012 04:54 PM
