1995 Bumper Blade
Old Feb 9, 2023 | 09:52 AM
steve95xjs's Avatar
Default 1995 Bumper Blade
My front chrome bumper blade has separated from the main bumper near the headlight washers. Can this be re-secured without removing the bumper? I'm not sure how it is connected in the first place. I'm assuming there are clips of some sort?​​​​​​​
Old Feb 9, 2023 | 10:40 AM
Keesh's Avatar
You have to adjust the side blade, it is attached to the car and not the bumper.
Old Feb 9, 2023 | 10:44 AM
steve95xjs's Avatar
Thanks. How do you access the screws? Is it from under?
Old Feb 9, 2023 | 11:24 AM
Keesh's Avatar
Through the wheel arch. 14 and 21 in the picture.
Vee's Avatar
Vee
What I usually do is go on eBay and see if I can find the part someone else is selling. Usually the pics show all side of the part and then I can kinda figure how its attached.
Old Feb 9, 2023 | 11:47 AM
steve95xjs's Avatar
I see how it connects - thanks for that. The sides are sitting flush to the bumper as is the middle - it is only pulled away at the headlight washers. It doesn't seem like adjusting the side or the middle will fix this. It seems like it's bent but it's the same condition on both sides. Has anyone else run into this? I suppose I can remove it and try to gently bend it back but wanted to know if someone has a better approach. Thanks again.
89xjsfix
Aug 15, 2021 01:41 PM
Pantherman2
Jul 6, 2016 03:32 PM
GhostriderXKR08
Feb 21, 2011 01:42 PM
ace10002
Mar 11, 2009 01:13 PM
