1995 Coupe Fuel Door
Old Apr 11, 2018 | 08:20 AM
EastRando's Avatar
Default 1995 Coupe Fuel Door
I have a 1995 XJS Coupe 4.0. A few days ago, I was gassing up and there was a significant amount of water behind the fuel door. I don't think any got into the tank, but it's still a concern.
Any advice on how to prevent this? A new fuel door? A seal of some sort? One of these parts?
https://www.jaguarclassicparts.com/u...seal-and-hoses
Thanks!
Old Apr 11, 2018 | 01:52 PM
MHF25's Avatar
Did you ream out the drain? Use a small gauge wire or a pressurized can of air. Look at the diagram you provided. The drain tube will get clogged at the Y junction due to debris from the boot drain. I used a small gauge wire to clear both tubes and also the tube of the right.
Old Apr 12, 2018 | 03:37 PM
EastRando's Avatar
Thank you, MHF25. I knew I was missing something obvious. I started trying to ream out the drain with some wire. I'll work some more on that this weekend, and make sure both it and the boot drain are clear.
Old Apr 16, 2018 | 09:20 AM
EastRando's Avatar
The wire did it! Both drains are clear now! Thanks again, MHF25.
Maxiv
Apr 11, 2018 11:32 AM
turbopower501
Aug 23, 2016 09:54 AM
Terry007
Aug 18, 2015 01:41 PM
reedjs
Jul 3, 2012 05:54 PM
nalin1017
May 28, 2010 10:44 PM
