1995 XJS Brake Overheating
Old Sep 2, 2025 | 08:31 AM
EastRando's Avatar
Default 1995 XJS Brake Overheating
Driving yesterday, I smelled a bit of hot plasticky intermittently. On a pretty busy road with a 55 mph speed limit, the pedal got very soft and the smell got worse. I pulled over onto a safe side street. There was smoke coming out of the front right side. I got out of the car, afraid that something had caught fire under the hood. No smoke under the hood but a little was coming out of the front right wheel well. The left front wheel was normal warm from driving. The right front wheel was very, very hot. I got a flat bed tow.
Later, at home, I took the right front wheel off. I wanted to see if there was anything obvious. I didn't see anything and I could spin the hub by hand. I'll measure the brake pads and disc later, but the pads had about 3mm of material left and the disc only had the slightest lip from wear.
What could the problem be?
  • Locked brake? Then the wheel wouldn't spin by hand, right?
  • ABS fault? I didn't hear or feel the pump operate.
  • Riding the brakes? I'd think both front wheels would have gotten hot.
  • Something else? Master cylinder?
Old Sep 2, 2025 | 03:30 PM
jal1234's Avatar
It's likely either a stuck caliper, or more likely, a failing brake hose for that wheel. The hoses fail on the inside, and start acting as a one way valve allowing you to brake, but the hose won't let the pressure release when you get off the brakes. If the car sits for awhile, the brakes will gradually release. If the hoses have never been changed, now is the time to do it. It's not hard or expensive if you DIY. Exercise the calipers at the same time, pushing the pistons all the way in, then using paint stir sticks between the pistons and brake rotor, step on the pedal and push them out. Do this several times.
while your at it, be sure to flush the brake fluid thru the system. 95 model year cars used two different designs of ABS. If your car has a rectangular brake fluid reservoir, there is a very particular way you need to bleed the brakes. There has been a lot of discussion here on the correct procedure. If your fluid reservoir is a triangle, you can bleed them pretty much as a normal brake system, as long as you don't let the reservoir go dry when bleeding them.
Jon
Old Sep 3, 2025 | 08:35 AM
EastRando's Avatar
Thank you, Jon, that sounds like the most likely cause.
I have the TEVES IV system, which I think means I can bleed them as normal as long as the reservoir doesn't go dry, as you mention. Is there anything I should know about the procedure or hoses? I have the service manuals and will check them out later. Does anyone know a good supplier for the hoses?
Old Sep 3, 2025 | 12:36 PM
Vee's Avatar
Vee
RockAuto has them pretty well priced.
Old Sep 3, 2025 | 01:02 PM
jal1234's Avatar
Rockauto is a good source.
Old Sep 3, 2025 | 01:42 PM
EastRando's Avatar
Any reason to go with the OEM Jaguar parts for 10x as much?
Old Sep 3, 2025 | 01:50 PM
jal1234's Avatar
No. Chances are they come from the same place in China that the aftermarket ones come from.
Jon
Vee's Avatar
Vee
Because you might love paying 10x more? You want to support your local Jaguar charity?
No. I have replaced one of my hoses from Rock Auto and I found no fault with the quality. Just pick a reputable brand from their offerings.
Old Sep 3, 2025 | 03:59 PM
EastRando's Avatar
Thank you, Jon and Vee, I'll take your advice!
Old Sep 3, 2025 | 08:41 PM
stuizzy's Avatar
I had this happen on my 1994 XJS. It was a sticking caliper. They will get so hot the brake fluid boils, hence no brakes. If this is your problem I would suggest rebuilding the caliper with new seals as the high temp may have damaged the existing ones.
When you remove the pistons clean the bores and pistons of any corrosion. The dust seal has probably failed letting water in. Other option is to get rebuilt calipers, relatively inexpensive.
I am not sure just exercising the pistons will fix the problem.
Also examine the brake pads for any damage (cracks) caused by the overheating.
Finally you may want to check the wheel bearings. The heat may have turned the grease to liquid
Old Sep 5, 2025 | 07:01 AM
EastRando's Avatar
Thanks, Stuart, good advice. I'll look into replacing the caliper, pads, and rotors while I'm in there. Will also check the bearings.
richa_sh
Oct 5, 2023 04:13 PM
JayJagJay
Jun 25, 2021 02:58 PM
SilvrSurfer
Jan 5, 2020 03:37 PM
lyonsfin
Jan 21, 2018 06:58 PM
hoodun
Oct 29, 2014 03:06 PM
