1995 XJS TIMING CHAIN- interference head?
Old Aug 31, 2015 | 09:17 AM
David Mason's Avatar
Default 1995 XJS TIMING CHAIN- interference head?
Before I get blasted I have searched the forums for the answer and I'm guessing the keywords I'm using aren't the correct verbiage.
I've got a chance to purchase a very nice 1995 XJS 4.0 i6 that has a timing chain slipped. Is the 4.0 an interference motor. I.e Do the valves smack the pistons when the timing slips?
Old Aug 31, 2015 | 03:13 PM
Flint Ironstag's Avatar
Good question, and welcome to the forum! First time I've heard of a timing chain slipping on these cars (doesn't mean much though). I don't know if it's an interference design or not. One of the experts will be along soon enough to enlighten us.
Got pics of the car?
Old Sep 1, 2015 | 06:58 AM
petemohr's Avatar
FWIW - I know the older 4.2 has an interference head so I'd assume that the 4.0 does also. But you know about assuming ;-))
Old Sep 1, 2015 | 11:17 AM
JTsmks's Avatar
Originally Posted by David Mason
Before I get blasted I have searched the forums for the answer and I'm guessing the keywords I'm using aren't the correct verbiage. I've got a chance to purchase a very nice 1995 XJS 4.0 i6 that has a timing chain slipped. Is the 4.0 an interference motor. I.e Do the valves smack the pistons when the timing slips?
I would love to see how a Jaguar 4.0 slipped a chain. Very, very, very hard if not virtually impossible to have happen.
Old Sep 1, 2015 | 01:20 PM
AdeV73's Avatar
Over-revved with a broken or underperforming chain tensioner is about the only way I can imagine it'd slip a tooth. Or it was put back together badly...
Old Sep 1, 2015 | 06:08 PM
baxtor's Avatar
Slipped timing chain seems to be the latest catchall for unknown engine problems. I suppose it can't ever be totally discounted but l wouldn't take the bet at the prevailing odds.
Old Sep 1, 2015 | 06:31 PM
JTsmks's Avatar
Having had mine apart on my x300 I can't even see that happening. It'd be pretty hard to do and would have to be a really neglected and abused example.
Old Sep 2, 2015 | 04:22 AM
ptjs1's Avatar
The AJ6 is an interference engine so I think every chance that the AJ16 is as well.
Still intrigued by the slipping chain....
Good luck
Paul
Old Sep 3, 2015 | 03:17 AM
melhookv12's Avatar
Good luck
Paul
What is more likely is failure of the chain guide material causing noisy chains.
Jaguar had a problem with these back when I was in the dealership. Can't remember which years exactly.
Also as we know there is a modified chain tensioner. Maybe the OP is being fed duff info.
SD96XJ6L
Jan 12, 2022 04:30 AM
Sprayall
May 30, 2021 08:13 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
