1996 XJS 4.0 keeps stalling
More information is needed.
Number of kilometres/miles on the vehicle?
What is the available battery voltage across the terminals with the ignition OFF when checked with a voltmeter?
What DTCs are stored?
Then check the gap on the crank position sensor. It's also something that should be replaced at this point.
Something is happening when the car gets warmed up and goes into closed loop.
Obviously you should invest $20 in an OBD2 reader to pull any codes the car is showing. Without that you are working in the blind.
I would first make absolutely sure you have no vacuum leaks between the throttle body, MAF and engine cam cover.
After that, I would ask you when was the last time the oxygen sensors were replaced.
After that, I might replace the crank position sensor, it’s an easy $20 part that can cause this problem.
AVRO XJS
Apr 11, 2024 06:11 AM
FS[NorthEast]: 1996 Jaguar XJS 2+2
Knomad
Sep 8, 2013 05:31 PM
