1996 XJS Transmission Mount Movement?
Old Aug 27, 2014 | 10:51 PM
SouthernGypsy's Avatar
Default 1996 XJS Transmission Mount Movement?
Does anyone know what should be the limits of the movement of the tail shaft of the transmission allowed by the tranny mount on a '96 4.0L Convertible?
Based on the design it looks like some movement is intended and I'm assuming somewhere there is a spec that says X amount of up/down or left/right movement is allowed but beyond that you need a new tranny mount (or to tighten something) but I can't find any reference anywhere.
Someone said if it clunks the bottom of the car when you go over bumps it's bad and while that's definitely good advice as a sign of a bad one I actually doubt it should have even near that much allowed movement so need to know how much is considered "normal" ... ?
Old Aug 28, 2014 | 01:09 AM
Japthug's Avatar
sorry to say there is no reference like that.
the mounting has a spring and that works as a shock absorber. the bushing works as a bump stop, so when the bushing goes bad it starts to making a clunk sound.
it won't be a problem if it moves as far as the spring travels.
aholbro1
Dec 29, 2024 06:46 PM
kevinl
Oct 31, 2019 06:15 PM
afterburner1
Dec 16, 2015 12:12 AM
ahunt4
Sep 14, 2015 08:17 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
