3.6-4.0 aj6 in a 1990 xjs
Old Jul 14, 2019 | 07:36 AM
krakenfelt's Avatar
Default 3.6-4.0 aj6 in a 1990 xjs
my project is going very smoothly, fitted a 4.0 aj6 and getrag 290 into my 1990 auto 3.6.
all good so far.
however after trying to connect the engine harness im having an issue. after it goes through the firewall and to the ecu area(a manual xj40 ecu) the yellow socket pictured below doesnt fit with the xjs one.
imgbb.com
IMG-2817
Image IMG-2817 hosted in imgbb.com
imgbb.com
IMG-2818
Image IMG-2818 hosted in imgbb.com
imgbb.com
IMG-2819
Image IMG-2819 hosted in imgbb.com
imgbb.com
IMG-2821
Image IMG-2821 hosted in imgbb.com
is it a case of identifying what cable does what and splicing together? i’m useless with electrics…
Old Jul 14, 2019 | 08:26 AM
Doug's Avatar
I don't see any way around it. In your case you might be able to remove the terminals and relocate them in the socket....rather than splicing wires.
In any case, you'll need to find out what the wires do
When I did my 6-cylinder to V12 conversion I had to spend a fair bit of time melding V12 circuits and looms into a 6-cylinder car. In some instances I was able to abandon V12 circuits, simplifying matters.
Hopefully someone with XJ40-specific experience will chime in with something more helpful
JensenHealey
XJ40 ( XJ81 )
Nov 18, 2024 04:12 PM
scarbro2011
Mar 27, 2016 04:41 AM
orangeblossom
Mar 30, 2014 05:29 PM
jmurray01
Non-Jaguar Vehicles
Aug 14, 2010 06:23 PM
