5.3 vs. 6.0 transmission mount spring, same size?
Anyone know if the transmission mount spring is the same size between a 3 speed auto v12 and the later 4 speed auto of the 6.0 cars? Part numbers are different but need to confirm if they are the same size
I measured a spring from an XJR, which uses the same transmission as the XJS, however it is a different part number. The XJR spring is 3" tall and 3-7/16" diameter.
The XJS 6.0 spring is still available from Jaguar quite reasonably.
6.0 4 speed auto spring is 3.5” tall and 3 2/16” outside diameter.
jal1234
Sep 1, 2022 12:42 AM
