6.0 and 5.3 bell housing bolt pattern
Old Feb 13, 2013 | 01:03 PM
calvindoesntknow's Avatar
Default 6.0 and 5.3 bell housing bolt pattern
are the 6.0 and the 5.3 using the same block bolt pattern for the bellhousing?
Old Feb 13, 2013 | 04:06 PM
ronbros's Avatar
NO, but can be adapted easily,. most important are the two locating dowels,GM alignment dowels to crank center line,depending on what trans. may have to get a adaptor plate, cheap from Summit or Jegs etc.
the 86 jag i looked at today used his 86 T400 adapted to the 6.0L, a 94 engine.
Old Feb 13, 2013 | 05:18 PM
I found a running 6l im going to have shipped. One reason I wanted it was the crankfire ignition. Stroke the 6l crank 5.5mm and have it hardened get a stroke of 84mm.
GordoCatCar
Jan 2, 2017 01:10 PM
perezal
Dec 24, 2015 04:16 PM
jorgef858
Nov 30, 2015 04:24 PM
jcwells
Sep 24, 2015 09:20 PM
1100me
Sep 7, 2015 06:26 AM
