83 XJS, runs great but no go?
Old Sep 15, 2008 | 07:23 PM
rpw00mirage's Avatar
Default 83 XJS, runs great but no go?
trying to figure out what is up with my buddies XJS.
car runs well, purrs like a kitten. doesnt smoke or leak a drop. coils just converted to single coil. no other modifications. low miles too.
even before the coil replacement this car feels like it has no go. we cannot diagnose anything wrong with the car, because it runs so well. any ideas? i can provide whatever info needed.
Old Sep 18, 2008 | 11:48 AM
Default RE: 83 XJS, runs great but no go?
help please...
he is probably going to sell the car soon. there is one at the local autox track that tears it up... would love to have this one run too.
Old Sep 18, 2008 | 10:21 PM
ontherun's Avatar
I don't know what you mean by no go but I have a 90 that would idle perfect but to give it gas it would stumble...changed the fuel pump and it runs like a scalded dog...keeps me pressed in the seat, I hear the cats get plugged easy and makes it lose power also...hope it helps..L
Old Sep 20, 2008 | 12:51 AM
i will have him check the converters first... its such a strange beast.
Old Sep 23, 2008 | 10:41 AM
oh, by "no go" i mean its not fast at all.
Old Sep 24, 2008 | 10:11 AM
new near tank fuel filter. cats are "hollowed".
is there another filter somewhere?
such a sexy beast! this is not the vehicle in question though... but it is very fast.
Old Sep 26, 2008 | 10:54 AM
ontherun's Avatar
there is a screen at the base if the tube in the small holding tank under the battery..thats it though...L
Old Oct 9, 2008 | 01:37 PM
ontherun > that was also checked. its a pure mystery!
im going this weekend to take pictures and video of the car. bear with me
i greatly appreciate the help so far. thank you gents!
Old Oct 9, 2008 | 01:53 PM
if you're all curious as to what i putt around in this is it -
Old Oct 9, 2008 | 06:06 PM
noonblueapples's Avatar
Put the car in low and floor it, it should pull you past 6,000 before the trans forces a shift, if it won't do this start by freeing up your distributor and re timing and see how it runs
Old Oct 13, 2008 | 09:20 PM
thanks i'll have to check that out.
so i drove the beaut for about 220 miles or so.
its a nice piece. great shape.
so it has an idle problem. when it gets under 38mph, the idle kicks up. my guess is some sort of FIAC valve or a bad vacuum line. im going to check this out. it also hunts at idle, i think between 500 and 1500 rpms. up and down.
the console doesnt light up completely and the e-brake doesnt work. gas gauge doesnt work. it definately sips gas!
it really feels as fast as my little evo up there that is only about 100whp.
are there any links to some sort of online shop manual?
Old Oct 18, 2008 | 10:14 AM
ontherun's Avatar
Ours was serching like that..I adjusted both throttle bodys and adjusted the screw on the side of the aav and it quit.. also I had a cracked hose running to it and it was sucking air...hope you get it fixed..it looks nice..our gas gauge didn't work untill I tapped on the glass with my finger and it works fine now...just stuck....L
Old Apr 22, 2009 | 01:03 PM
And I'm back! The Jaguar is out of storage and back on the road. So far I've fixed a bunch of little things, like all the lights, brakes and such to get it road ready.
I have a few problems left. The car still runs mint but slow. I have not yet checked the timing but will within the next week or so.
Windshield wipers do not work. We replaced the motor with a known good one but still cannot get any power. I wonder if it has anything to do with the switch.
Fuel gauge and sender are having trouble. The gauge does not read on the dash. I measured the voltages at the sender.
FULL- 3.76 volts
100 miles - 3.64 volts
150 miles - 1.5 volts
I'm guessing the sender could possibly be bad, as well as the gauge?
No reverse lights. Voltage at the bulbs is about 1.x volts. I'm thinking I should pull apart the center console and check the reverse switch for the lights.
I have this horrible Haynes shop manual for this and about 5 other Jags around this 1983 model year. Is there a better manual I can download on the internet somewhere? I checked out the JITS but it does not go back far enough for this car.
Any help would be greatly appreciated
Old Apr 23, 2009 | 09:23 AM
We have determined with the wipers that the column stalk is OK, and so is the wiring all the way to the cannon plug on the cowl. Also, the harness that connects from the cowl to the motor is good. The motor is bad.
toronadomike
Jan 22, 2026 10:13 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
allenman85
May 10, 2021 03:11 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
