83 XJS Salisbury differential drain plug help
Old Aug 1, 2019 | 03:14 PM
Mike Lore's Avatar
Default 83 XJS Salisbury differential drain plug help
1983 XJS . Hi,hoping you guys can help. I changed the differential fluid a few days ago and now it's leaking from the bottom plug.previous owner had it in there halfway threaded in. Never seen that before. Didn't see any thread damage but I'm sure there is. Anyway,what would you recommend in this situation? Help
Old Aug 1, 2019 | 05:28 PM
Jagboi64's Avatar
It should be a tapered pipe thread, so I wouldn't expect the plug to go all the way in. I coat the threads with Loctite 567, thread sealer before installing the plug and so far no leaks.
Old Aug 1, 2019 | 09:40 PM
Agreed,
1/2"BSP from memory??
ALWAYS some sport of sealer on those threads, its "steel on steel" as we say.
Only choice, drain it again, let it drip out, HOT is Vegas at the moment, so drink beer for an hour or 2, then refit WITH sealer, and refill the diff, simple.
DO NOT get stupid with a long bar etc, you WILL snap it off and be in more shiit.
Old Aug 6, 2019 | 02:57 PM
Mike Lore's Avatar
[QUOTE=Grant Francis;2107108]Agreed,
DO NOT get stupid with a long bar etc, you WILL snap it off and be in more shiit.[/QUOTEPut on loctite took my time went on easily no leaks. Thank you
Ltd
Oct 3, 2018 07:45 PM
plums
Feb 20, 2015 02:52 PM
EricF
Jul 31, 2014 08:50 PM
scrible
Oct 24, 2012 10:01 PM
EricF
Mar 26, 2011 05:24 AM
