Differential drain plug
Old Oct 1, 2018 | 08:28 PM
Ltd's Avatar
Ltd
Default Differential drain plug
I want to thank the many forum members who posted their experiences with removing and reinstalling the diff fill plug. I now know what a wobble extension is. Mission accomplished. Ninety eight convertible has a body brace across the fill plug. Ninety seven k miles, no debris on plug. Removed 1.9 liters. No evidence of leakage. All is good. I used Lucas synthetic 75w90.
Old Oct 2, 2018 | 10:18 AM
Johnken's Avatar
Congratulations!!! Nice job.
John
Old Oct 2, 2018 | 08:15 PM
zray's Avatar
NOTE: if the car is driven hard, even infrequently, then it can be beneficial to use a 75w-140. Mobil1 75w-140 is a good one.
......just sayin'
Z
Old Oct 3, 2018 | 02:48 PM
David F.'s Avatar
Just curious , did you use the cutting the hole in the trunk sheet metal method to get access to the fill plug?
Old Oct 3, 2018 | 07:45 PM
Ltd's Avatar
Ltd
Default Cut hole
I did cut a 2" hole. I tried from underneath. Just wasn't happening. I'll primer, paint, and plug the hole. The wobbly extension worked great getting it out. Reinstalling, it would be wise to have a second set of hands, to avoid cross threading. I finally used the wobbly to reinstall. Just no way I could get it in otherwise.
al_roethlisberger
May 15, 2018 08:00 AM
plums
Feb 20, 2015 02:52 PM
Sinister 1
Nov 1, 2012 05:41 PM
khsmith55
Aug 13, 2011 12:40 PM
IrishXtype
Oct 28, 2010 01:11 AM
