84 v12 engine valve adj-When
Old Sep 24, 2014 | 11:08 PM
big john's Avatar
Default 84 v12 engine valve adj-When
1984 xjs v12, 5.3, he. since I don't know the history of this car-speedo shows 80k miles-? I don't now if the valves have been adjusted. Should the valves make a small 'clicking' noise like a sewing machine--or be 'quiet'. This V12 has NO valve clicking at all, wondering if the valves are too tight. Large job to just check the valve clearances. Car runs good & smooth.
Old Sep 25, 2014 | 01:50 AM
Greg in France's Avatar
The valve clearances will be fine. Drive the car and forget them. They are such that, unless there has been a materials failure, they cannot really change significantly. The tappets are not noisy on a V12.
To measure the clearances involves removing the induction, then the cam covers and then measuring. To adjust them involves removing the camshafts and the timing chain and lots of other grief - all completely unnecessary Believe me, they are fine!
Greg
Old Sep 25, 2014 | 05:14 AM
As Greg said, worry not.
Come back in about 200k miles time and they will be the same.
The V12 should be almost silent, even by todays engine standards.
One warning, you may or may not this one.
NEVER EVER overheat that engine. If you do, the concern about valve clearances will be the least of your worries.
SOOOOOO, the cooling system cleanliness, INSIDE and OUTSIDE is paramount.
None of mine run hot, V12 or the pretend engined ones, never have, and we have 46c+ summers to deal with.
Kevin Burnaby
Jun 28, 2020 08:04 AM
Doug
Feb 27, 2019 01:31 AM
cissdm
May 3, 2016 06:02 AM
Bowman
Sep 15, 2015 06:54 AM
d a
Sep 3, 2015 02:34 AM
