85 XJS Tranny-no high gear
Old Feb 22, 2012 | 11:59 PM
ncng's Avatar
Default 85 XJS Tranny-no high gear
Hello,
An 85 XJS, will run in 1st and 2nd, no high gear? Maybe a servo?
Thanks,
ncng
Old Feb 23, 2012 | 03:43 AM
warrjon's Avatar
I would be checking the vacuum line that runs from the RH inlet manifold to the transmission, if this is leaking or come adrift it will give you this sympton.
Old Feb 23, 2012 | 06:39 AM
87XJSCoupe's Avatar
Could be a couple of things...or more, but the easiest to check are the vacuum modulator and it's vacuum line that comes from the right side manifold, rear. The modulator is on the left side of the trans. I had a similar problem and tried to swap it with a common GM one. I could never get it to shift as smoothly as the Jag on and had to pay the piper for a new one...around $60 or so.
The other is the governor. It is located on the top right side of the trans and accessed through a removable plate in the floor under the carpet. It is near the dash end of the tunnel. You can pull up the carpet to get to it. The governor on the GM TH400 has a small plastic gear that is known to strip. Not very hard to replace and a cheap part. I had a couple extras and have them on ebay. It is centrifugal and sometimes will stick. A lot of info and pics on the Internet about these two problems since the trans is a GM TH400 with a special cast bell housing to fit the V12.
1100me
Jul 24, 2023 06:10 PM
tomsjag
Jun 10, 2023 10:02 AM
afterburner1
Dec 16, 2015 12:12 AM
user 652867429824
Oct 28, 2015 10:18 AM
hen555
Sep 7, 2015 11:13 PM
