86 HE blowing hot air
Old Dec 6, 2020 | 05:21 PM
Jacko5711's Avatar
Default 86 HE blowing hot air
I don't seem to have any vacuum to the heater valve - I assume that vacuum is required to close the water valve? I think there is a solenoid somewhere to apply vacuum? Can anyone tell me where it is and a part numer? Tks
Old Dec 6, 2020 | 06:19 PM
macdoesit's Avatar
Banned
There is a metal modual on heater hose next to firewall, probably rusted and not closing. Others that know more than I will chime in.
Old Dec 6, 2020 | 11:47 PM
Doug's Avatar
Vacuum to the heater valve is controlled by a switch located on the servo assembly. There are two identical switches, part # RTC1076. The inner of the two is for the heater valve
However, these don't fail often.
Do the various vacuum actuated air flow flaps operate when you change the settings? If not, you might have a vacuum supply problem--no vacuum getting to the control switches.
Do you hear a faint whirring sound if you slowing adjust the temp dial? You should. If not, the servo is not operating...and the servo actuates the vacuum switch for the heater valve.
Old Dec 6, 2020 | 11:53 PM
Doug's Avatar
I'll add that I'm assuming you have the Delanair Mk II climate control. But an "86" might have the Delanair Mk III system. The Mk III system is easily identifiable as the temp control dial has a "Pull for manual control" feature.
If you have the Mk III, post back. It's a different kettle of fish.
Old Dec 7, 2020 | 04:55 PM
BradsCat's Avatar
I have a Mk III unit in both my '87 and the '88 H&E I am parting out. I still haven't been able to get the unit out even though I have removed every nut or bolt I could find.
What might I be overlooking or not looking in the right place? The rest of the dash, console and facia is already removed so access is not an issue. Thanks.
PS...that V12 engine cleaned up and sitting on the heavy duty pallet with wheels I built sure looks awesome :-))
Old Dec 8, 2020 | 01:12 AM
Greg in France's Avatar
Brad
It probably need a good sharp shove. The insulation can stick the unit to the bulkhead.
Bismuth08
Mar 6, 2019 01:36 PM
Rkr45
Jan 30, 2017 08:23 AM
studentper
Oct 15, 2016 09:50 PM
adenshillito
Feb 8, 2016 10:41 AM
heflirob
Oct 21, 2015 06:39 PM
