88 v12 won't start or crank
Old Nov 24, 2015 | 03:32 PM
asleach2889's Avatar
Default 88 v12 won't start or crank
Got off of work early and tinkered with the jag a little bit. It currently doesn't have a battery and hooked it up with jumper cables to see if the fuel pump made noise, which it did. Then turned the key and nothing, not a sound to be had(yes I was still hooked up via jumper cables). My question is where I should start looking for possible culprits for the starter not doing anything?
Old Nov 24, 2015 | 04:14 PM
baxtor's Avatar
I would start by jumping wires at the starter relay. That will tell you if you have a good starter motor or not. If not check the main battery feed connection on the firewall post and from there l guess it is ignition switch, gear selector micro switches, fuses etc.
Old Nov 24, 2015 | 04:46 PM
Safari's Avatar
Before you start diagnosing problems the first thing you need to do is to install a fully charged battery.
It takes a lot of current to turn the starter. Unless you are using seriously large jumper cables I doubt the starter is receiving the current it needs to turn.
Put a battery in the car. Then you will know if you have a real problem or not.
Mark
Old Nov 24, 2015 | 06:42 PM
warrjon's Avatar
Yep,,,,,, Most jumper cables are not heavy duty enough to start a car with no battery installed.
Old Nov 25, 2015 | 11:41 AM
JagCad's Avatar
Ditto:
Electric diagnostics must start with a fully charged battery. then, good cables clean and tight on each end.
I wandered way off course a bit back while chasing a "no brake light" issue. battery went plumb (0) in the midst of the hunt. Much false negatives and lost time....
Carl
TweeTwee
Nov 10, 2015 01:56 AM
cyber3d
Oct 27, 2015 04:50 AM
Ragn0r
General Tech Help
Oct 26, 2015 10:54 AM
Ragn0r
Oct 26, 2015 10:25 AM
LowellLamb
Oct 25, 2015 08:55 PM
