88 XJS WOT switch
Old Jun 24, 2012 | 12:17 AM
mmxjs88's Avatar
Default 88 XJS WOT switch
The Wide Open Throttle (aka enrichment) switch on my 88 XJS broke so I got a new one. However the new one has 3 terminals while the old one had two so it can be connected so that it is either normally open or normally closed. The old switch is too broken for me to tell what it was.
So, my question is: Is the switch supposed to be normally closed or open? The service manual doesn't even mention the switch.
Marvin
Old Jun 24, 2012 | 12:44 AM
Doug's Avatar
Normally open
Old Jun 25, 2012 | 04:47 PM
Evo160K's Avatar
mmxjs88,
Open is my understanding also. I replaced my switch a couple of days ago and hooked it normally open, it was three prong instead of the two I took off. Haven't tested it yet.
Old Jun 25, 2012 | 08:54 PM
macboots's Avatar
Just did this the other day to my kickdown switch... they are identical...
Normally open.
I bought mine from Grainger's... was $4 or so...
Old Jun 27, 2012 | 09:19 PM
macboots's Avatar
Found my Grainger's receipt. If anyone is looking for a replacement wide open throttle or kickdown switch in the future (they seem to deteriorate and fall to pieces over time), the Grainger's item number is 6A885. Lever arm is straight, but marked on the arm at the point to apply the bend. Will require you to put the kink in.
Cheers,
Will
Old Jun 28, 2012 | 06:16 AM
Evo160K's Avatar
Will,
That's good info. Thanks
toronadomike
Jan 22, 2026 10:13 PM
Forcedair1
Sep 8, 2025 01:57 PM
tonyforman
Sep 10, 2015 07:23 PM
1100me
Sep 7, 2015 06:26 AM
laserguy
Sep 3, 2015 02:02 PM
