89 XJS, Rear Calipers rebiuld.
Old Mar 24, 2012 | 02:15 PM
thuffner3's Avatar
Default 89 XJS, Rear Calipers rebiuld.
Why is this statement made in the Alldata site?
I need to separate these halves to hone the piston cyclinders.
NOTE : Do not under any conditions, remove or attempt to remove bolts securing halves of caliper together.
TIA
Peace
Neil
Old Mar 24, 2012 | 03:55 PM
Fraser Mitchell's Avatar
OK. This instruction is there to stop amateurs from separating the two halves and then using "Jo Noname" bolts to fix them together again. The bolts used are normally special high tensile material and designed to be used once and once only. If you have a source of bolts of the required specification, and have the torquing instructions then go ahead, otherwise leave alone. For calipers with an internal fluid passage across the two halves, there is normally also an 'O' ring seal and this should always be replaced at the same time. If it was me, I would try to find a place that does a service exchange for your calipers. I did this when rebuilding the rear subframe on an XJ6 around 1996.
Old Mar 24, 2012 | 07:52 PM
thuffner3's Avatar
Thanks Fraser,
I have seen a few posting that lean toward that.
But wanted to be sure, have no quames about replaceing spec bolts.
Thank you.
Old Mar 24, 2012 | 08:53 PM
thuffner3's Avatar
Should have finsihed my last posting.
What are the spec's for the required bolts?
I can get any bolt I require.
And what would the torgue be?
TIA
Old Mar 25, 2012 | 12:03 AM
warrjon's Avatar
Hi Neil
I was going to hone my front calipers due to the amount of rust on the pistons. I was told by a guy who does Jag brakes under NO circumstances hone the calipers they WILL leak.
He advised me to use fine wet and dry sand paper wet and lightly go over the area that is effected.
I have seen Jaguar caliper bolts on eBay.
FrickenJag
Jun 16, 2025 02:15 PM
mbergen
Oct 23, 2019 10:26 PM
GordoCatCar
Jan 2, 2017 01:10 PM
RaceDiagnostics
Sep 7, 2015 07:28 AM
philwarner
Sep 5, 2015 10:05 AM
