90's radio code factory settings solution
Old May 7, 2026 | 04:52 PM
Steve Lockwood's Avatar
Exclamation 90's radio code factory settings solution
For those of you who like original equipment and have a radio without a code and want music while working on car, here is the fix on most to set code to 1324. there is an access under label where there are solder connections, the 2 solder connections determine the code. if you break the 2 solder connection the code is factory 1324. If you have a radio out and know the code, post the connections that are soldered and the corresponding code so we can make a cheat sheet! Time to load the CD magazines and jam while I work! Found this at https://carstereohelp.com/stereoremovalJaguar.htm
03_jaaag
May 18, 2024 12:02 AM
ericthexjs
Aug 3, 2023 08:35 PM
KASSER
Oct 29, 2019 12:25 PM
Fla Steve
Jun 27, 2018 07:17 PM
Jagbro
XJ40 ( XJ81 )
Feb 7, 2017 04:57 PM
