Dash warning bulb replacement.
Old Apr 16, 2025 | 08:58 PM
flyingphil's Avatar
Default Dash warning bulb replacement.
I am wanting to replace the dash warning bulbs (all 20) with LED bulbs...so i can actually see them, particularly in direct sunlight. I have removed the instrument cluster, but still have no idea how to access the bulbs. Do I go in through the back, or through the plastic cover at the front? Also, what are the bulb model? I can't see it listed in the various manuals?!
Old Apr 16, 2025 | 10:29 PM
flyingphil's Avatar
I found some videos of bulb replacement on earlier XJS models, but not the 'face lift'?!
Old Apr 16, 2025 | 10:32 PM
Scottsxjs95's Avatar
Hi Phil, I used superbright B 8.5D, but I used 17, 3 regular for Ignition, check engine and sport. Also replace the 5 larger ones that illuminate the gauges 194- BCOB 1w Blue. Be sure to test the bulbs after you install might have some polarity issues and or contact issues, I used a small 12volt battery. The contacts are kinda fiddle. Hope this helps
Scott 95 XJS convertable
Old Apr 16, 2025 | 10:35 PM
The big blue ones are the five larger ones, all access from the back
Old Apr 17, 2025 | 08:09 AM
malc4d's Avatar
Quicksilver Automotive
Old Apr 17, 2025 | 09:08 AM
Vee's Avatar
Vee
Originally Posted by malc4d
I think the Jaguar Dealer in Beverly Hills would charge you less for these bulbs!
Old May 2, 2025 | 11:33 PM
flyingphil's Avatar
Oh, that's brilliant! Thanks for that. So do you just twist the bulb holders from the back? I see what looks like a little "X" of sodder at each bulb holder and am a little afraid of damaging something.
Old May 3, 2025 | 09:59 AM
Yes the bulbs just twist out 1/4 turn or so, be careful of the printed circuit, the copper is very thin, it is easy to test the bulbs once installed buy following the path of the contact back to the plug in . Buy the way the five larger bulbs make the biggest improvement for brighter gauges, use blue ones.
Jon89
Dec 1, 2019 02:49 PM
Geofflvmyjag
Oct 7, 2015 09:24 AM
Frog
Jun 24, 2014 03:51 PM
e21pilot
May 23, 2014 07:49 AM
redvette1986
XJ40 ( XJ81 )
Feb 3, 2011 07:26 PM
