91 xjs CONVERT. ELECTRICAL SHORT
Old Aug 22, 2010 | 11:26 PM
buddys 12's Avatar
Default 91 xjs CONVERT. ELECTRICAL SHORT
keep blowing 10 amp fuse for brake lights. brake switch is good and changed brake relay. all light sockets look good. ANY IDEAS?signal lights work fine.
Old Aug 26, 2010 | 11:10 PM
Sarc's Avatar
I assume you only blow the fuse when you put your foot on the brake pedal ?
Does your car have the high mounted stop light on the trunk lid ?
If so, take that apart and have a look if you haven't done so already. All of the connectors inside there are bare, so it's very easy for them to get bent and short out.
I had this issue when I had the high mounted stop light off during a respray. I have now installed some upholstery foam between the + and - wires to prevent future shorts.
Old Aug 27, 2010 | 07:15 AM
cbgbglavan's Avatar
Default short
I have also had problem with the 3rd brake light.
took it out.
Kept getting rear bulb failure, could not find bad bulb or fuse.
Then 1 day car died. All my fuse were grounded but not blown.
took days looking for a short. Finally realized somehow third light for some reason had tripped the fuel inertia switch. With 3rd light out got power back after resetting switch.
Old Aug 28, 2010 | 11:04 PM
buddys 12's Avatar
thanks for the help but third light seems fine. I am going to check break failure unit under center consul
Old Aug 30, 2010 | 10:04 AM
buddys 12's Avatar
I took the center consul apart and disconnected the brake light warning unit. I then bypassed the unit with wire and lights now work fine. Will probably leave as is. THANKS AGAIN.
aholbro1
Dec 29, 2024 06:46 PM
Rivguy
Dec 4, 2020 07:55 AM
mbergen
Oct 23, 2019 10:26 PM
XJsc-guy
Nov 23, 2015 01:56 PM
1100me
Sep 7, 2015 06:26 AM
