92 xjs v12 thermostat location?
Old Feb 21, 2008 | 08:17 PM
jag_genius's Avatar
Default RE: 92 xjs v12 thermostat location?
they are relatively easy .. the car has2 of them .. open hood.. you will see 2 .. hoses about 2 inch in diameter they go into the front of the engine to a aluminum housing both sides.... you will have to remove air cleaners.. and you will see them .. 3 bolts hold the housing together .. on both sides..
Old Feb 21, 2008 | 08:19 PM
jag_genius's Avatar
does your coolant switch ever move? maybe it is running good.. just the temp switch is dead.. relay if i can remember is on the driver side.. i think it is the 1st or second relay..blue
Doug
Feb 27, 2019 01:31 AM
vinny jones
Oct 5, 2015 07:20 AM
DrTripp
Sep 14, 2015 07:58 PM
1100me
Sep 7, 2015 06:26 AM
d a
Sep 3, 2015 02:34 AM
