'93 glove box stuck closed
Old Mar 7, 2011 | 03:53 PM
Britcarguy's Avatar
Default '93 glove box stuck closed
Somehow the glove box on my '93 XJS got stuck closed. The knob turns so I know it's not locked but the door will not open. Any suggestions as to how I can get the door off without damaging the wood facia?
Old Mar 19, 2011 | 08:31 AM
Britcarguy's Avatar
Default Got it open
Thanks for the tip Paul. I did get the glove box (aka cubby) open but in this case I had to pry it down. On the lock cylinder there is a nub that sticks out the end opposite the key that engages a sliding tab that goes behind the catch plate when the door is closed. Rotating the lock makes that nub pull the tab down to clear the catch plate and the door opens. On my car the nub broke off the lock cylinder so the tab was permanently un the "up" or latched postion. Prying down very carefully with a wide flat bar where the glove box door meets the catch plate flexed the door down far enough for that tab to clear and the door opened. Then I removed the lock cylinder, drilled a small hole where the nub broke off and inserted a tiny screw to mimick the nub. I ground the head of the screw down a bit so it was the same size as the nub. Then I assembled it and it works just fine.
BlacXJRcat
35
Oct 21, 2025 03:49 PM
BadKat174
May 26, 2023 12:29 AM
XJsc-guy
Nov 23, 2015 01:56 PM
tvholden
Sep 12, 2015 11:13 AM
Sprayall
Sep 3, 2015 07:49 PM
