94 convertible front speakers not working
Old Apr 11, 2021 | 12:46 PM
OldCoastie's Avatar
Default 94 convertible front speakers not working
The radio works fine and sound from the back speakers is great. Balance works but I don't see a way to "fade" from from to back to front.
Old Apr 12, 2021 | 10:47 PM
Brewtech's Avatar
To the left of the volume button there is a fader that can be swung up and down, along the edge of the volume button. I bet the lever is set all the way down. Just raise it til your speakers come on. Number 15 on the picture diagram
Old Apr 13, 2021 | 09:22 AM
OldCoastie's Avatar
The 94 radio doesn't have the slider.
Old Apr 13, 2021 | 10:57 AM
OldCoastie's Avatar
It was there after all. I was just being a DA.
Thanks for your help!
Old Apr 13, 2021 | 11:05 AM
speeedracer's Avatar
We've all been there
Old Apr 13, 2021 | 01:38 PM
Brewtech's Avatar
Just read you found it. Lol. Its easy to miss
Old Apr 13, 2021 | 01:40 PM
Brewtech's Avatar
Im sure you found it because I can see it.
Old Apr 17, 2021 | 08:24 PM
OldCoastie's Avatar
You would think that after changing the fuel pump, the wiring harness under the hood, the engine monitoring ECM, the charcoal evap canister, purge valve, EGR, fuel pressure regulator, seals to the fuel lines, fuel filter, two convertible top hydraulic lines, plugs and wires, one tail light and one side marker light and various relays and switches I might be qualified to adjust the fade on my radio. Guess not!
Some times being a little ADD is not helpful. (except when you own a Jag)
Still have front springs and calipers before I paint it.
D.C.
16
Jan 14, 2022 04:25 PM
Redhead
May 3, 2017 11:46 PM
ez53436
Dec 12, 2011 08:53 AM
I <3 X-Type
Sep 29, 2010 02:42 PM
housegroove77
May 24, 2007 02:50 PM
