94 L6 Running Lean - White Plugs
1994 L6 130k --runs great, been insanely reliable for last 10 years.
I am trying to get past smog once again. This time I failed for running too lean. I pulled the plugs and they were pure white verifying the lean condition. Before getting it smogged it was throwing a O2 sensor code like it often does. Replaced it with a Bosch O2 sensor and the code went away like it always does. So back to the lean condition.
I checked for air leaks and did not find any. I replaced the fuel filter and it did not help. One odd thing is that ocassionally the car idles up and down and then starts idling higher and higher --indicative of an airleak though when I unplug the IACV it goes back down to normal and everything is fine no more run away idle or up and down idle. Car idles perfectly at 650 when stopped at lights etc. Its fine until I unplug the battery and then it does the up and down run away idle things. No check engine codes. ...but it fails smog for being lean...
So what exactly controls the air fuel ratio when not at idle. Since the car failed smog at 25mph and 15mph. Is it the O2 sensor that gives the reading that adjusts the injectors? Could I have the wrong O2 sensor? 94 only has one and its downstream... Would the IACV also effect when not at idle? Maybe some sort of internal leak or its sticking?
Lots of questions and Im all over the place here. Basically, trying to solve a lean condition.
Hi Hoodun
I've never done this on my Jag but I've done it on my Merc, which 'may or may not help you'
(1) Check the Fuel Pressure
While I know you've changed the Filter it 'Could' (only 'Could'!) be a Failing Fuel Pump (let's hope not)
(2) Check the IACV (Idle air control valve)
Stone Cold Engine: Start the Car and then unplug the IACV (then turn off the engine) do NOT allow the Engine to Warm up!
Remove the IACV and measure the Piston, which will (should) extend on Start Up to allow more Fuel in
Replace the IACV plug it in, then Start the Car only this time let the Engine Warm up
Then with the Engine Still Running (Unplug the IACV) and THEN Switch off the Ignition
The reason you would do that is to Freeze the IAVC Piston in 'Time' which wouldn't happen if you just switched off the engine
Then Remove the IAVC and measure the Piston in the IAVC again, where you 'may' find that the Piston in the IAVC is Stuck
As I say not done this on a Jag but this was the problem on my Merc and I managed to fix it
Maybe the IAVC Piston is Sticking on the way out and not fully extending
Here’s what sensors affects fuel
enrichment:
1. TPS
2. Coolant Temp Sensor
3. Oxygen Sensors
4. MAF sensor
This is for the AJ16 engine. I’m assuming the AJ6 works about the same way. You won’t have an OBD2 port to read the sensors so this may be tricky.
First, unplug the Coolant Sensor. Short the two position plug so the engine thinks it’s hot. (Perform this when the engine is indeed hot). And see what happens...or just replace the $25 part. It might be time anyways.
The other possible culprit is the MAF. You’ll have to backprobe and check readings while someone else sits in the car and revs the engine, in park of course. Do you have a multimeter?
enrichment:
1. TPS
3. Oxygen Sensors
4. MAF sensor
enrichment:
1. TPS
3. Oxygen Sensors
4. MAF sensor
enrichment:
1. TPS
3. Oxygen Sensors
4. MAF sensor
The easy answer is to go to your parts store and get a can of MAF Cleaner. Not electrical contact cleaner, but MAF Cleaner. It'll say so on the aerosol can. Then take off the MAF and spray her up and see what happens.
The other option is to have someone press the gas while you take voltage readings at the MAF harness and/or the ECU pins.
I'll have to check my manual to see what the proper readings should be, but in the meantime, go get some MAF Cleaner!
Idling high is indicative of a air leak in the sense that its lean, which doesn't have to be from extra air. My 4.2 bent a valve from running lean (I hunted all over for vacuum leaks for he high idle) and it turned out to be poor fuel pressure from clogging.
Would recommend checking fuel pressure as well as getting a vac gauge to help look for leaks.
How do I get to the MAF sensor. I pulled the entire piece out and even unscrewed the two screws to pull the sensor but it was stuck in there via wires. I didn't want to pull too hard so I screwed it back... The new ones are only sold as one entire piece so I am thinking its not made to come out, which makes it impossible to clean.
You can spray the MAF cleaner through the mesh to get to the sensor.
The mesh also comes off. I think it will pull off if you pry it loose. Then you’ll have unobstructed access to spray down the wire sensor. Do not touch the sensor wire. A good spray down should do the trick.... if that’s what’s ailing it.
rogerdodger
Sep 23, 2012 06:49 AM
