94 xjs v12 6L
Old Nov 3, 2017 | 01:09 PM
lovjags's Avatar
Unhappy 94 xjs v12 6L
Hi Need help
NO start no spark changed dis. rotor, coils . cap, wires, plugs
have code. ff 45. someone said change parts. db 12507-8. lost
Old Nov 3, 2017 | 01:17 PM
Jagboi64's Avatar
FF45 is a bad O2 sensor, that's not related to no start.
Given the parts you have changed, are you sure that everything is assembled correctly and all properly seated? Wires connected back as they were before? Plugs properly making contact in the coils, same for the wires? All it would take is the lead from the coil to distributor to not be making contact and you have no spark. All the plug wires connected in the proper order? It's easy to get them mixed up.
Have you tested to see if you have a spark?
Old Nov 3, 2017 | 03:48 PM
warrjon's Avatar
Check the connectors on the front and rear crankshaft sensors, if these are bad then you will have no spark.
This can be done from under the car. The front one is just below the damper and the rear one is on the LHS where the transmission mates to the engine.
Old Nov 3, 2017 | 07:38 PM
sidescrollin's Avatar
Do you have 12v to the coil with ignition on?
Old Nov 3, 2017 | 11:40 PM
lovjags's Avatar
Hi thanks for the response
yes I have power to both coils one wire lights up on both when I turn key
Old Nov 3, 2017 | 11:42 PM
lovjags's Avatar
Hi I did one at a time all good
Old Nov 3, 2017 | 11:44 PM
lovjags's Avatar
Hi the first problem was I lost a bank only running on 6, thats when I changed everything, after that no start
Old Nov 4, 2017 | 01:26 AM
warrjon's Avatar
You should have power on all the wires on the coils when you turn the ignition on, that is White, White/Brown and White /Black.
Old Nov 4, 2017 | 08:29 AM
lovjags's Avatar
Hi Warrjon only one wire is lighting up
Old Nov 4, 2017 | 08:33 AM
lovjags's Avatar
the A bank front coil has 2 wires, B bank rear coil has 3
Old Nov 4, 2017 | 11:14 AM
Old Nov 7, 2017 | 11:43 AM
lovjags's Avatar
Red face engine harness v12 6L
Hi. Any one know were I can find engine ignition
wire harness, top of engine
part # LHD-3350AB
my vin 194521, THANKS
Old Nov 7, 2017 | 01:39 PM
warrjon's Avatar
I was going to say you might have a problem with the harness. I have never seen anyone advertise them. You could make your own or take it to an auto electrician and have them make a new one for you.
Old Nov 7, 2017 | 01:43 PM
lovjags's Avatar
yes looks like it,have to look in hemming for someone
Old Nov 8, 2017 | 12:42 AM
warrjon's Avatar
To test the harness you could remove connectors at BOTH ends, and meter the cable.
Check continuity end to end on each wire then check all wires have NO continuity to ground.
Old Nov 8, 2017 | 09:13 AM
lovjags's Avatar
Hi everyone, great news car started and is running an all 12. All I did was unplug
and then plug back CPS wire and it started right up. but now the trans light is on and its not shifting into high gear???
Old Nov 8, 2017 | 09:15 AM
lovjags's Avatar
Smile cat is purrrrring
thanks for all the help
Old Nov 8, 2017 | 09:17 AM
lovjags's Avatar
I need engine wire harness????? anyone out there that can rebuild
