94 XJS V12 soft top
Old Sep 25, 2021 | 02:08 PM
alabbasi's Avatar
Default 94 XJS V12 soft top
All, I've owned my XJS convertible for years but have never driven it much. The soft top won't open either electrically or manually. Even when I unlatch and put my shoulder into it. What's the procedure for manually lowering the top?
Old Sep 25, 2021 | 02:15 PM
ptjs1's Avatar
Turn the pump valve to manual. It's a T-handle on the top of the pump.
Turn the two-T-buckle clips 90 degrees on the pump trim cover in the boot. (Be careful, you can't buy those clips)
Wiggle the trim cover out.
You'll see the pump. The T-valve is on the top and is marked where to turn it to manual.
Then you can lower the roof. It's quite stiff as you're pushing the fluid manually through the struts
The failure of the roof operating can be a number of things, but is more likely to be the switch on the handbrake not making than contact than anything else.
Good luck
Paul
steveq
Jun 27, 2019 09:03 PM
1995XJSGuy
May 10, 2018 10:06 AM
charlie2
Jun 30, 2017 03:28 AM
brinny
Mar 5, 2016 08:28 AM
orangeblossom
Jun 22, 2014 05:59 PM
