95 4 liter AJ16 shifting hard
Old Feb 22, 2012 | 02:24 PM
Spikepaga's Avatar
Default 95 4 liter AJ16 shifting hard
Hello all!!
My AJ16 XJS is shifting hard when coming out of a stop and I am feeling kickdown a little too much. Ever since I have owned the car it has done this on and of , just seems to go away on its own. Do you all know if my transmission is still controlled by a cable?? I imagine that is the problem
Thanks !!
Old Feb 22, 2012 | 07:13 PM
M90power's Avatar
4l80e?
Old Feb 23, 2012 | 06:28 AM
MustangSix's Avatar
Originally Posted by m90power
4l80e?
ZF 4HP24 on the AJ16 engines.
Old Feb 23, 2012 | 09:24 AM
M90power's Avatar
is it vaccum modulated such as the th400? if so, a loss in vaccum pressure from a leak or such, a disconnected vaccum hose, or a bad vaccum diaphragm will cause MAXIMUM line pressure in a vaccum momdulated transmission, such as the TH400.
this will cause hard upshifts and downshifts.
Old Feb 23, 2012 | 12:14 PM
Spikepaga's Avatar
Thanks all for the replies. I do not know what is causing it but its been shifting poorly even in higher gear.
I think the ZF is mostly electronic, but if it still has a cable, that may be the culprit, I think
Old Feb 25, 2012 | 03:38 PM
M90power's Avatar
what do you mean by cable? there are still plenty of transmissions with electronic valvebodies that use vacuum to control line pressure and shift firmness.
4t60e is a perfectly good example.
user 652867429824
Oct 28, 2015 10:18 AM
reb1999
Sep 19, 2015 07:30 AM
mrplow58
Sep 15, 2015 09:58 PM
tsimms7
Sep 15, 2015 12:43 PM
jerry_hoback
XJ40 ( XJ81 )
Sep 13, 2015 07:48 PM
