ABS and Brake light intermit on
Old Sep 28, 2011 | 06:13 PM
asnakeintx's Avatar
Default ABS and Brake light intermit on
I recently bought this 1990 XJS sight unseen on ebay. Although in fair condition, there are some items that seem to be Jaguar typical. One concern is the brakes.
> The brake fluid looked very bad so I flushed the system by vacuuming the master cylinder and bleeding the calipers. I used fresh DOT 4. However, a before and after condition remains. When driving and using the brakes infrequently or upon first using the brakes, the ABS and BRAKE warning light will illuminate for a few seconds. If I pump the brakes the light will illuminate the first time, go out, then stay out through the pumping. Other than that, the brakes seem to work fine. I am just afraid that the ABS module may be getting flaky. What else could you suggest I look for?
Old Sep 29, 2011 | 05:47 PM
lfc_ozzie's Avatar
I had the same kind of problem when i first got mine the ABS light was on constantly, turned out the insulation around the wires in the wheel arch was a bit dodgy so taped it up with electrical tape until i could fix/replace. hope this helps
Old Sep 30, 2011 | 10:41 AM
cadfael_tex's Avatar
Mine was similar to lfc_ozzie. I had a bit of wire to the ABS sensor perished on one of the rear wheels that was causing it.
H20boy
Dec 24, 2024 03:23 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
PMKimpton
Aug 3, 2019 08:22 PM
motorhead69
Sep 9, 2015 10:04 AM
innzane
Sep 2, 2015 10:08 AM
