ABS light on after bleeding
Old May 18, 2023 | 09:52 AM
maccasa's Avatar
Default ABS light on after bleeding
I suffered a problem of pulling to one side which turned out to be a sticky solenoid in the Teves ABS unit. I replaced the complete unit using one from an XJ6 and the system is now wonderful. HOWEVER the ABS light is now staying on all of the time. We bled the LP side at the accumulator (no bubbles) and the rear and front brakes as per Teves instructions. Any thoughts?
Old May 18, 2023 | 10:59 AM
ptjs1's Avatar
maccasa,
Good to hear that the ABS valve block change was successful. Perform the Blink Test routine and see what codes are stored in the ABS.
Good luck
Paul
Old May 18, 2023 | 02:46 PM
Vee's Avatar
Vee
Any particular year so we can attempt to figure out which Teves ABS system you're referring to?
rethorets
Dec 29, 2021 01:28 PM
dbunt101
Dec 19, 2021 07:36 AM
bullittandy
Mar 3, 2017 04:44 PM
Saspc
May 26, 2016 05:58 PM
orangeblossom
Jul 13, 2015 04:24 AM
