ABS pressure ball availability
Old Nov 9, 2014 | 11:40 AM
Daim's Avatar
Default ABS pressure ball availability
Hi there,
I've read here before, that the Teves ABS System needs a working pressure ball in Order to work properly. If I press my brakepedal 4 times the pump turns on and builds up pressure
I assume the pressure ball isn't working right. Are they still buyable? If so, what is the parts number?
Damien
Old Nov 9, 2014 | 12:38 PM
sainmatt's Avatar
25528382 is the acdelco part that is identical to the jag part for 1/4 the price. They are listed all over online but there was a nationwide back order apparently.
I found mine from a Chevrolet dealer their website is karlautoparts.com.
Old Nov 9, 2014 | 01:37 PM
Brake buster's Avatar
they are still available from Jaguar, but are not ' cheap ' whatever that is, JLM 1907 @ £170 plus VAT ( for the XJ40 but will fit the XJS )
the one from the XJ40 also fits , and can be got from breakers, but no guarantee that they will work like a new one
getting one from the US will be expensive , again , whatever that means to get a working braking system
BB
Old Nov 12, 2014 | 09:49 PM
Stargazer XJS's Avatar
The Lincoln Mark VII had a Teves system as well, and the accumulator ball was always one of the more sought-after pieces.
If the pump cycles after four stomps on the pedal, you're still in good shape, but an ounce of prevention and all that. If the pump fires every time you step on the pedal, then you might want to prioritize the ball.
As I recall, replacing them requires that you pump the brake pedal something like 50+ times with the car off to alleviate the pressure in the system before removing the accumulator.
Old Nov 13, 2014 | 05:36 AM
HeWhoDaresRoy's Avatar
Pretty sure you can get it refurbished by these guys in the UK:
http://www.mycitroen.dk/library/ds/r...c/Pleiades.pdf
Olly
Old Nov 13, 2014 | 07:10 AM
Doug's Avatar
BB
Just wondering.....
Doesn't GM and/or AC Delco operate distribution centers in the UK and/or continental Europe?
I have to think there is *some sort* of GM presence over there that would allow you guys easier and more affordable access to "GM stuff" like the accumulator ball
Old Nov 13, 2014 | 07:56 AM
you would think so , wouldn't you
however, as it is the UK, and wider Europe, they hike the prices compared to the US
I recently rebuilt my GM400 box, and imported all the parts from the US , as it still worked out half the price than buying in the UK
BB
bamforp
Aug 14, 2024 05:36 PM
1100me
Jul 24, 2023 06:10 PM
JagBrian
Sep 21, 2015 07:17 PM
Pilotman11
Sep 18, 2015 11:35 PM
innzane
Sep 2, 2015 10:08 AM
