Can anyone tell me where the fuse is for the lighting (bulbs) in the AC Climate Control Panel (that surrounds the radio) on a 94 XJS? The panel itself works but the illumination stopped after I, like a fool tried to tighten one of the bulbs while the ignition was on. Im certain I blew the fuse as I saw a spark.
I have searched everywhere with no luck including the factory electrical manual.
When I shorted out the bulb, it burned out "something" in the climate control plugin that the climate control panel plugs into. Luckily, I had a spare. The bulbs now work on the panel. I do not think there is a fuse. It is very stupid for Jaguar not have it fused.
This happened to me what exactly did you burn can you help me out with more descriptive info?
1995 might be different from 94 but I looked into my plug I don't see anything burnt.
I had to replace the "AC Panel Control Interface Module" which is behind the control panel. I am attaching mine with the note I wrote on it. There is one currently on EBay for $29.99. Hope this helps! It was one of the most frustrating things I had done working on my cars!
Sounds excellent! Could you shoot some pics of the burnt resistor, part, and replacement? I could possibly save my damaged one. My email: benzjag@hotmail.com
