AC drain
Old Jul 25, 2020 | 11:37 AM
rwolak's Avatar
Default AC drain
Ran into a little issue today. It’s been very hot/humid this month and, when using the AC, I can hear water slouching around behind the dash. Never was a problem until today when water started dripping out from behind the passenger side fuse panel ( this is a 1994 convertible w/4.0L engine).
Does anyone know where the AC system should be draining off excess moisture.
Old Jul 25, 2020 | 11:39 AM
Greg in France's Avatar
If you look under the car, each side of the gearbox, but high up in the tunnel, you will see a plastic drain tube. Poke a bit of wire up each tube.
Old Jul 25, 2020 | 12:48 PM
rwolak's Avatar
Ok thanx. Will give it a shot.
Old Jul 25, 2020 | 08:25 PM
Xjeffs's Avatar
With my trans out, I can get a picture of the AC drains.
Old Jul 26, 2020 | 06:10 AM
rwolak's Avatar
Found them. Had a tooth pick stuck in the passenger side drain. How that got in there I'll never know.
Kevin - Houston
Sep 13, 2020 09:30 AM
daywin
Nov 22, 2014 04:33 PM
amcdonal86
Jun 8, 2011 02:56 PM
