Accelerator Question
Old Sep 24, 2012 | 08:46 AM
mannymux's Avatar
Default Accelerator Question
Guys,
When I start my car, the accelerator is a little hard to press down to move the car, but if I allows it to warm up for a few minutes, then it works fine. What might be the issue? Thanks...
Old Sep 24, 2012 | 08:55 AM
Doug's Avatar
Dirty throttle bodies? Sticky/corroded cable?
You disconnect the cable at the engine end and then, next morning, see of the pedal is easier to operate. If it is, then the problem isn't related to the cable itself.
Old Sep 24, 2012 | 10:58 AM
mannymux's Avatar
But why does it work fine after the engine is warmed up?
Old Sep 24, 2012 | 11:18 AM
Doug's Avatar
Sometimes mechanisms that are sticy loosen up with heat
Old Sep 25, 2012 | 07:36 PM
Greg Edge's Avatar
The dried up grease melts or the sludge on the throttle bodies softens.
xjrjag
Oct 24, 2024 03:09 PM
yoiyoi
Dec 19, 2023 12:51 AM
Forcedair1
Feb 19, 2020 01:51 PM
ajacks86
Oct 12, 2017 08:51 PM
XFR_Gold
Sep 2, 2015 12:24 PM
