Ahh perfect
Old Jun 2, 2017 | 04:13 PM
944xjs's Avatar
Default Ahh perfect
Always a great feeling
Old Jun 2, 2017 | 04:57 PM
Jagsandmgs's Avatar
That's why it's easier to tap the aluminum intake and not those steel tabs
Old Jun 2, 2017 | 05:33 PM
warrjon's Avatar
Get yourself HSS or Tungsten (TC) taps and this will not happen. I have broken nearly all of my carbon taps, as they break I replace them TC a little more expensive but well worth the additional money as they cut far better/cleaner thread.
Old Jun 2, 2017 | 11:34 PM
944xjs's Avatar
Luckily I went and got another better tap and finished the rest.
This was my first time using a tap.. I could tell after the first 4 the metal seemed to be getting hotter and tougher... then snap!
Old Jun 3, 2017 | 09:58 AM
JagCad's Avatar
Do you use cutting oil? As it seems you are using a drill press or other motor, rather than a manual drive.
I rarely use power to thread or tap, relying on hand tools. I do have a selection
of power, drill press included.
Carl
Old Jun 3, 2017 | 02:14 PM
ronbros's Avatar
darn, i'm left out again.
my manifolds dont have any holes, neither the heads!
Old Jun 3, 2017 | 04:47 PM
944xjs's Avatar
Carl
dont tell anyone... I didn't use cutting oil the first tap 🤡 I did just use hand tools though.
Old Jun 3, 2017 | 05:28 PM
warrjon's Avatar
For cutting fluid I use Auto trans fluid as I have loads of it, you can also use WD40
Old Jun 3, 2017 | 10:38 PM
275nart's Avatar
I have a set of 12 with the holes already welded if you want them just cover shipping. I decided to just weld the holes on the manifolds when I pulled them off.
Old Jun 4, 2017 | 07:46 PM
944xjs's Avatar
Thanks for the offer, but I got them all setup and done.
Old Jun 4, 2017 | 09:28 PM
Eaa's Avatar
Eaa
If you are making new threads HSS is the way to go - those carbon steel taps they sell at the hardware store aren't good for much beyond cleaning up existing threads. Cutting oil helps a lot too - WD40 is good for aluminum, for steel I use "pipe threading oil", the heavy dark brown smelly stuff. That's a pretty multipurpose cutting oil. If you are going to do lots of tapping, there's stuff made especially for that purpose - "Tapmagic" I think is one name that comes to mind. If you are tapping a hole that you can't get to the other side of, giving the tap a heavy coat of grease helps hold on to the chips so they don't fall inside somewhere you can't access to clean.
Hope this helps! Eric
Old Jun 4, 2017 | 11:23 PM
944xjs's Avatar
Originally Posted by eaa
if you are making new threads hss is the way to go - those carbon steel taps they sell at the hardware store aren't good for much beyond cleaning up existing threads. Cutting oil helps a lot too - wd40 is good for aluminum, for steel i use "pipe threading oil", the heavy dark brown smelly stuff. That's a pretty multipurpose cutting oil. If you are going to do lots of tapping, there's stuff made especially for that purpose - "tapmagic" i think is one name that comes to mind. If you are tapping a hole that you can't get to the other side of, giving the tap a heavy coat of grease helps hold on to the chips so they don't fall inside somewhere you can't access to clean.
Old Jun 5, 2017 | 09:30 AM
275nart's Avatar
Glad you got it sorted. If anyone else has a use for them, the offer stands.
