Air Condioning Compressor Clutch Shaft Sheared Off...Question?
Old Dec 19, 2017 | 01:52 PM
Anglicomarine0326's Avatar
Default Air Condioning Compressor Clutch Shaft Sheared Off...Question?
The A/C clutch locked up and the shaft (pictures) broke. The pulley spins freely and I was able to simply slide off the broken clutch and piece of shaft. Can I continue driving the car with this piece removed? Is the pulley securely on? I drive daily but will replace the entire compressor in spring. Can I wait? It's always something!
Old Dec 19, 2017 | 02:44 PM
Daim's Avatar
If you don't have an air pump, just cut the belt and all is fine. It is a rare thng for the shaft to snap. The co pressor is definately dead and scrap metal now. You won't be able to salvage any A6 parts.
Or just get a new compressor. Any single groove metric Harrisn A6 will fit. They don't cost much at all.
Old Dec 19, 2017 | 05:03 PM
I do have a functioning air pump, so I am reluctant to snip the belt. I realize that the compressor is cheaper than my mechanics labor cost, and will swap it out in spring. I simply want to know if the pulley is secure as its spinning freely? As I said earlier the clutch assembly bolt sheared off. What holds the pulley in place?
Old Dec 19, 2017 | 10:59 PM
Doug's Avatar
From memory...
The pulley is a press-fit and has a snap-ring retainer as well.
Typically you need a puller to remove it after removing the snap-ring. I don't think you have to worry
When time comes to replace the compressor you need to determine if you have a "Superheat switch" type or the "HSLP" type. "High Side, Low Pressure"
Old Dec 19, 2017 | 11:38 PM
Daim's Avatar
As Doug said. The pulley is pressed onto a bearing which in turn is pressed onto the front cylinder head. It won't just fall off.
Daim
Jul 17, 2016 11:10 AM
orangeblossom
Sep 27, 2015 11:32 AM
steeevo
Jun 30, 2014 12:53 PM
mrsambem
Feb 25, 2014 02:44 PM
