Air temperature switch
Old Nov 21, 2018 | 12:03 PM
brinny's Avatar
Default Air temperature switch
on the rear of the right hand air box / filter housing, is an air temperature switch. Can you tell me how this may affect the running of the engine if not in perfect condition. Reason I ask is mine has a crack in the back and I will need to refit using gasket paste as both part and gasket are no longer available. Is it critical to the car or not so important? Many thanks for your assistance once more.
Old Nov 21, 2018 | 12:52 PM
carsnplanes's Avatar
From what I've read on the engine management system, either for V12 or 6, the air temp can effect detonation, so with hot air entering the air box, the sensor will tell the ECU to slightly retard the timing to avoid pinging.
Old Nov 21, 2018 | 01:47 PM
brinny's Avatar
Thanks. It wouldn’t prevent the car starting then? It would give me a clear sign if it was kaput by pinking?
Old Nov 21, 2018 | 02:28 PM
No. A sensor like that is under the category of 'Correction" sensors. Primary sensors are TCD crankshaft position sensor for starting and flywheel speed sensor for running. I would check the TDC sensor as that is what signals the ECU for fuel.
Old Nov 21, 2018 | 03:10 PM
brinny's Avatar
Right thank you. I don’t have a known problem but wanted to know what to look for and what it did as I begin the long journey of restarting the car. Now I know what it does and what symptoms are of this part failing. Much obliged.
Old Nov 21, 2018 | 05:56 PM
VancouverXJ6's Avatar
You can check its function at idle, observe/hear the idle sound with and without it plugged in, you'll know.
https://www.britishparts.co.uk/jagua...mperature-p763
Old Nov 22, 2018 | 12:42 AM
brinny's Avatar
Ok thanks.
Old Nov 22, 2018 | 12:51 AM
warrjon's Avatar
There are 3 primary sensors for the Marelli ECU these are
TDC sensor on the front of the crank
Engine speed on the flywheel
MAP sensor which is inside the Marelli ECU
Correction inputs are
Air intake temperature switch - the one you are referring to on the right airbox.
Idle switch on the LH throttle body linkage
Engine coolant temperature on the right water manifold.
john_cook12
Mar 2, 2020 01:03 AM
rgp
Oct 22, 2019 08:56 AM
Daim
Mar 12, 2019 07:09 PM
86jag
Jul 13, 2016 10:13 AM
Whitecatt
Jun 5, 2013 11:01 PM
