Alternator upgrade
Old Jun 18, 2017 | 12:04 PM
JigJag's Avatar
Default Alternator upgrade
I have a Bosch 14383 - 115 Amp alternator that I'd like to replace my alternator with. I have several complications to deal with.
1. No fan. No Pulley.
The new alt does not come with a fan or pulley. The ones from my OEM alternator will not fit. The shaft on the new Bosch unit is much too large. I'm going to take it to a local alternator rebuilder and see if they can provide me a fan and pulley. If not, I'll try to locate these online. Any tips here are appreciated.
2. Too many connections.
The new unit has 3 connections. My old unit, has only a spade and a single heavy gauge lead.
I am assuming that the spade goes to the "W+" on my new alt, and that the heavy lead with an eyelet goes to "B+" on my new alt.
What, if anything, do I need to connect the "D+" on the new unit to?
Also, If I were to want to provide a supplemental ground for the alternator, can I just go from one of the body bolts to the chassis? Can I just use heavy primary wire?
Here's a pic.
Anyone done this particular replacement before?
Old Jun 18, 2017 | 05:00 PM
warrjon's Avatar
D+ connects to the dash light
W outputs an AC voltage proportional to alternator speed and is not used in your case. This can be used in a diesel application for tacho
Old Jun 19, 2017 | 01:16 AM
Greg in France's Avatar
For clarity, this is what the spade connector on the wire from the loom must be connected to.
greg
Old Jun 19, 2017 | 03:44 AM
warrjon's Avatar
greg
Yes. The spade connector on the loom should go the D+ terminal on THIS alternator.
The W terminal on THIS alternator is not used.
Old Jun 19, 2017 | 05:21 AM
JigJag's Avatar
Thank you both very much! I really appreciate it!
I dont understand how this information was not easily searched, but I suppose most people just reconnect the existing harness.
