Antenna/Aerial Question
Old Feb 26, 2019 | 03:56 PM
Mac Allan's Avatar
Default Antenna/Aerial Question
I wanted to repair my Hirschmann 6000el electric antenna and bought a replacement mast. I took it apart to make sure there wasn't any of the old toothed cable in the unit, and to inspect the works. It was very clean and looked fine.
Reinstalled in the car, and if I turn the radio on I can hear the motor run. However, when I turn the radio off, wait for the delay, the motor does not reverse/run so I can feed the new mast in. I removed the cover on the delay relay to see if the relay was either stuck or not operating, but it appears to be working fine.
What am I missing?
Thanks for your help!
Old Feb 26, 2019 | 05:44 PM
afterburner1's Avatar
If everything is free and well lubricated, I would look to relays.It is best to pull the schematic and trace the wiring I would also look at the antenna rod connection and insure that is smooth and not binding. I would also suspect the down delay circuit. If the motor isn't working that might be the problem
Old Feb 27, 2019 | 10:57 AM
Mac Allan's Avatar
It appears to me that the problem is the internal relay board inside the Hirschmann unit. Is there an off the shelf board or relay I could use to replace it? Could someone with a little more EE knowledge let me know? Thanks!
Here is the schematic:
Old Feb 28, 2019 | 10:28 AM
My approach, if you can get to them, is to burnish the relay points; replacement would be a better choise The schematic does does not show where M6 connection to the center box goes unless it goes to 1br on the radio. Since the antenna goes up that indicates the motor is running.I would also suspect the relay being frozen in the up position. I think the radio provides the current to raise the antenna. and the relay stays in the up position and when the radio is turned off, the relay relaxes into the down position.
Moseleykmc
May 13, 2020 11:50 AM
coudamau
Jan 3, 2014 12:04 PM
Sarc
May 21, 2013 02:52 PM
Fozberry
Mar 24, 2012 10:07 AM
cgrcar
Mar 18, 2008 02:40 PM
